Activity › Forums › Apple Final Cut Pro Legacy › bouncing two clipsin one without losing dimensions
  • bouncing two clipsin one without losing dimensions
    Posted by Alex Gat on April 1, 2014 at 8:35 am
    Hello,
    I have a problem.
    I have a clip that I have scaled and moved to correct a bad frame.
    On this clip, I have a sudden movement that I have corrected using speed.
    For that I have split the clip in two portions, one of which is now slowed down.
    The final touch is to add a smooth cam. The problem is that the effect acts differentely on both clips creating a bump when jumping from one clip to the other.
    Usually I bounce the clips before adding the smooth cam but as my clips are already scaled I don’t need the smoothcam to scale them again.
    But if I bounce before adding the smoothcam, I loose the opportunity to avoid rescaling because when bouncing I loose the off frame portion of my clips.
    Thus my question :
    can I bounce without losing the original dimensions of the clips ?
    I guess I could do the following :
    – first smooth cam
    – second correct speed
    – third correct scale and frame
    Yes, sure next time that what is I will do, but I don’t want to do it all over again.
    Any suggestion ?
    Steve Eisen replied 12 years, 6 months ago 2 Members · 1 Reply
  • Steve Eisen
    April 1, 2014 at 2:17 pm
    Your smoothcam is automatically adding movement on your clip. You really need to do this outside of FCP. After Effects or Motion may help.
    Fixing in post is a bitch!
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Creative Pro Users Group
