Activity › Forums › Maxon Cinema 4D › bouncing ball not rotating correctly
  • bouncing ball not rotating correctly
    Posted by Durlon Bryant on November 9, 2008 at 9:09 pm
    hi! I’m kinda new and couldn’t find anything on this. I’m doing the bouncing ball tutorial, and I can get the ball to bounce, using dynamics and all…but the rotation of the ball is wrong. How do I get the ball to rotate in the direction of the bounce? I know there are friction objects for particles, are there some for objects? I’m looking for help with the friction. thanks
    Juan manuel Lynch replied 17 years, 5 months ago 3 Members · 3 Replies
  • Brian Jones
    November 10, 2008 at 2:19 am
    It’s all in the settings for Rotational Mass and the two frictions Static and Dynamic (well, mostly dynamic in this case) You have to play with the settings to get what you want but here’s an example
  • Durlon Bryant
    November 10, 2008 at 4:39 am
    ok that works perfectly! thanks!
  • Juan manuel Lynch
    April 28, 2009 at 6:44 pm
    hi,
    Im getting same problem here, but with a soft body. Changing dinamic or static, either in the softball or in the plane, seems not to make any effect. I cant try rotational mass as softbodies dont have this option. i also tried playing with drag fields, but it only made me feel i had no control.
    Any ideas?
    by the way, when i try to give the soft body an initial force nothing happens but initial velocity works. It drives me crazy not knowing…
    thanks in advance.
