Activity Forums Apple Final Cut Pro Legacy Bounced audio unsync with original sequence…
  • Bounced audio unsync with original sequence…
    Posted by Kazumi Hatori on August 2, 2010 at 6:46 am
    I’ve been working on a short film.
    Having the audio been mixed by the mixing guy,
    I get the mixed audio bounced from Protools.
    Then I import to FCP and find the audio is out of sync.
    But what weird is that the length is the same and the waveform looks sync to video!
    then I did one more try:
    export the video, and put it in After effects together with the bounced audio. Exported few formats and all are fine and sync!
    Did I mess up with my FCP settings?
    I’m using brand new 27″ iMac with FCP7.
    thanks!
    Kazumi Hatori replied 16 years, 1 month ago 2 Members · 2 Replies
  • John Fishback
    August 2, 2010 at 9:20 pm
    Jeremy Garchow came up with a workflow that might help: First, delete the new mix out of FCP and your timeline. Set FCP up in a 23.98 or 29.97 easy setup (whichever applies), then quit FCP. Now reopen FCP and reimport your new mix. The file should be in sync.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
  • Kazumi Hatori
    August 20, 2010 at 8:51 am
    thanks for reply first!
    did a try but won’t work…
    I’m working on Prores422 25p sequence,
    does that matter?
