Activity Forums Adobe After Effects Expressions bounce text effect
  • bounce text effect
    Posted by Ermal Koci on December 18, 2017 at 6:06 pm
    Hello,
    I was looking at the bounce code from Dan, and couldn’t wrap my head around it (maybe mr. Dan should make an extensive tutorial about expressions like these)
    the expressions takes the value from layer keys and bounces that value back.
    How do you convert this expression so that it doesn’t use keys but text Amount values from text “Animators”?
    Thanks.
    e =0.7;
    g = 3000;
    nMax = 12;
    n = 0;
    if (numKeys > 0){
    n = nearestKey(time).index;
    if (key(n).time > time) n--;
    if (n > 0){
    t = time - key(n).time;
    v = -velocityAtTime(startVal )*e;
    vl = length(v);
    if (value instanceof Array){
    vu = (vl > 0) ? normalize(v) : [0,0,0];
    }else{
    vu = (v < 0) ? -1 : 1;
    tCur = 0;
    segDur = 2*vl/g;
    tNext = segDur;
    nb = 1; // number of bounces
    while (tNext < t && nb <= nMax){
    vl *= e;
    segDur *= e;
    tCur = tNext;
    tNext += segDur;
    nb++
    if(nb <= nMax){
    delta = t - tCur;
    value + vu*delta*(vl - g*delta/2);
    }else{
    value
    }else
    value
    Ermal Koci replied 8 years, 7 months ago 2 Members · 2 Replies
  • Andrei Popa
    December 19, 2017 at 8:13 am
    Is this what you are looking for?
    delay = .03;
    myDelay = delay*textIndex;
    t = (time - inPoint) - myDelay;
    if (t >= 0){
    freq =3;
    amplitude = 100;
    decay = 6.0;
    s = amplitude*Math.cos(freq*t*2*Math.PI)/Math.exp(decay*t);
    [s,s]
    }else{
    value
    The expression is not mine, I have it from a project I bought a long time ago, so I guess its an anonimous author.
    Andrei
    My Envato portfolio.
  • Ermal Koci
    December 26, 2017 at 4:45 pm
    Yeah,
    I have seen this script before. Problem is that this is not exactly bounce, is more an “overshoot” effect. Bounce should bounce to an invisible plane and return, with the frequency going smaller until it stops.
    Thanks.
