Activity › Forums › Adobe After Effects Expressions › bounce in (by expression?)
Posted by David Modijefsky on August 10, 2006 at 11:27 amI’m looking for an expression to pop (or bounce in) texts or elements on screen. So it looks like the text comes in a little closer to the camera, then wiggles back in scale to it’s actual size. Does this description make any sense? I did a few searches and tried keyframing but didn’t came up with what I’m looking for.
Dan Ebbertsreplied 20 years, 1 month ago 3 Members · 7 Replies
David Modijefsky
August 10, 2006 at 12:00 pmOops, I did a search without ‘archives’ checked on. Now I’ve found ‘squach & stretch’ from Dan which I was able to modify to my needs with my limited knowledge of expressions. That leaves me with 1 question though. The expression only works when the layer starts at frame 0. How do I alter the code so that I can move the layer in point where ever I like? The problems are in lines 4 and 5 I guess. This is what I have so far:
max_dev=20; // max deviation in pixels
spd=35; //speed of oscillation
decay=10; //how fast it slows down
x=scale[0]+max_dev*Math.sin(spd*(time-in_point))/Math.exp(decay*time);
y=scale[0]+max_dev*Math.sin(spd*(time-in_point))/Math.exp(decay*time);
[x,y] -
Dan Ebberts
August 10, 2006 at 3:11 pmThis should do it:
t = time – in_point;
s = max_dev*Math.sin(spd*(t))/Math.exp(decay*t);
value + [s,s]Dan
Mike Clasby
August 10, 2006 at 4:01 pmYou might find this useful, and the I have a question for Dan. Here’s the same thing triggered by a marker set on the layer (From one of Dan’s earlier posts):
n = 0;
if (marker.numKeys > 0){
n = marker.nearestKey(time).index;
if (marker.key(n).time > time){
n–;
}if (n == 0){
value;
}else{
t = time – marker.key(n).time;
value + [s,s];
}Question for Dan, I hacked the above from a “Marker Triggers Move” expression of yours, my question is, can I make the Trigger specific to a markers name, like one marker triggers a Move and a different marker (same layer)triggers a Squish and Squash?
Dan Ebberts
August 10, 2006 at 4:10 pmIt depends on which version of AE you’re running. You can’t access the comment in the newer versions but you used to be able to with marker.value. Hopefully this very useful feature will be restored in a future version.
Dan
David Modijefsky
August 10, 2006 at 9:29 pmThanx Dan! So if I have expression questions in the future it’s wise to specify which version of AE I’m running?
Dan Ebberts
August 11, 2006 at 4:39 pmSure, that would be helpful. Especially if it’s not the latest version.
Dan
