Activity Forums Maxon Cinema 4D Bounce expression/technique for rotation?
  • Bounce expression/technique for rotation?
    Posted by Hunter Hempen on February 8, 2013 at 2:58 pm
    Greetings,
    I’ve been scouring the internet for an C4D expression similar to the After Effects bounce expression, but I guess some people use other methods to achieve a vertical bounce through shaders and delays.
    I can’t, however, find any way to bounce a word via rotation. In AE you could paste in the expression, and keyframing the X value (for example) would induce a rotational bounce.
    Is there any method for this aside from keyframing rotation in C4D?
    Hunter
    Too bad she won’t live! But then again, who does?
    -Gaff
    Adam Trachtenberg replied 13 years, 7 months ago 3 Members · 2 Replies
  • Brian Jones
    February 9, 2013 at 4:03 am
    An easy way is to use the Mograph effectors Plain and Delay. Tim Shetz has a tut here https://www.c4dtraining.com/blog/?p=34 that uses these for a movement bounce but it can just as easily do a rotation bounce. He’s using cloners but it can also work without cloners with the effectors used as deformers, just use the same settings for the Delay
  • Adam Trachtenberg
    February 9, 2013 at 5:46 pm
    Another option is to use the constraint tag’s spring constraint.
