Activity Forums Adobe After Effects Expressions Bounce at regular interval
  • Bounce at regular interval
    Posted by Aharon Rabinowitz on July 18, 2007 at 9:07 pm
    Hi there-
    Can anyone help me with an expression that makes a layer bounce at a constant pace. I want to time a bouncing layer to the beat of some music, so the expression would need to be minutely adjustable.
    The bounce part needs to be a linear keyframe and the zenith of the actual bounce needs to be an ease in/out. I will animate the position X by hand – possibly with a null, if the expression does not alow the layer to have its position keyframed.
    So basically, like a karaoke ball standing in place.
    Make sense?
    Thanks.
    Aharon
    Aharon Rabinowitz
    arabinowitz(AT)yahoo(DOT)com
    http://www.allbetsareoff.com
    Click the link below to subscribe to the Creative Cow After Effects Podcast, and get free AE video tutorials:
    https://phobos.apple.com/WebObjects/MZStore.woa/wa/viewPodcast?id=111087911
    Dan Ebberts replied 19 years, 2 months ago 2 Members · 3 Replies
  • Dan Ebberts
    July 18, 2007 at 9:44 pm
    Aharon,
    If you keyframe one cycle of the bounce with three keyframes, add a slider to set the bounce period and another for the bounce start time, something like this should work:
    period = effect(“period”)(“Slider”);
    bounceStart = effect(“start”)(“Slider”);
    t = ((time – bounceStart)%period)/period;
    valueAtTime(linear(t, key(1).time, key(3).time))
    You’ll probably want to reduce the slider ranges to give you finer control.
    Dan
  • Aharon Rabinowitz
    July 19, 2007 at 7:18 pm
    Thanks. I’ll give this a shot.
    So my understanding is that the distance between the keyframes doesn’t matter, right? The expression is what controls the actual timing?
    Aharon Rabinowitz
  • Dan Ebberts
    July 19, 2007 at 7:39 pm
    Yup, that’s how it should work.
    Dan
