Activity Forums Adobe After Effects Expressions Bounce at marker?
  • Posted by David Modijefsky on February 18, 2010 at 10:23 am
    Hi there,
    I did a search first and tried a few expressions but they didn’t work for me. Here’s what I want to do. I have a layer that only moves down in y-direction between 2 keyframes. When arriving at the 2nd keyframe I want the layer to simulate a bounce. I think I need a script that works with a marker as trigger for in point. Am I correct? I’m working in CS4. Thanks in advance!
    what will this button do?
    David Modijefsky replied 16 years, 6 months ago 2 Members · 2 Replies
  • Todd Kopriva
    February 18, 2010 at 4:11 pm
    This expression should get you started:
    “Expression example: Animate scale at each layer marker”
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
  • David Modijefsky
    February 22, 2010 at 7:35 pm
    Thanks Todd. I was in such a hurry that I had to solve it with ordinary keyframes. Not as smooth of course. I wil look into your solution now. Much appreciated.
