Activity Forums Maxon Cinema 4D Boujou-Cinema4d-after effects.. wont work!
  • Boujou-Cinema4d-after effects.. wont work!
    Posted by Kurt Hudson on June 14, 2010 at 8:05 pm
    I have spent the last 3 days trying and trying to get this workflow to work for me but I am having multiple problems.. I shot the footage on the canon 5d mk2 1080 24p and opened it and tracked it fine in boujou.. saved the dimensions of my Z and my X and placed a test object in boujou and it worked perfect.. I exported both as a c4d file and a lightwave file and both seemed to export fine.. I try to open my video file as a texture in luminance and color both and set it as a background but either way its just a black sphere and I set it as a background and it says texture error when I try to render a sample.. thats one problem I have. the next problem is when I set up my render settings.. the original footage has 444 frames but everytime im ready to export i click ALL FRAMES and it says 0-444f but at the bottom it says its only exporting 427frames.. I set up the frame rate correctly to 23.976 and still nothing.. Next problem.. when I try to export the file to an AEC for after effects it wont even open.. please help me!! Here are some photo refferences to my set up..
    https://s759.photobucket.com/albums/xx240/Khudsonfilms/cinema%204d%20problems/
    let me know what I am doing wrong, thank you so much!
    Tim Shetz replied 16 years, 2 months ago 2 Members · 1 Reply
  • Tim Shetz
    June 14, 2010 at 8:30 pm
    As far as the video as a texture, there is a problem with the latest update for Quicktime. If you upgraded recently, you’ll need to downgrade to get it to work. We just ran into this problem a couple of weeks ago at the school I teach at. We had to downgrade several hundred machines to get it to work.
    Found this thread here on CC:
    https://forums.creativecow.net/thread/19/869494
    You can find the previous versions of QT here:
    https://support.apple.com/downloads/#quicktime
    As for the Boujou issue, I’ll defer to someone else…I’ve not used it enough.
    Hope that helps.
    Tim
    C4DTraining.com
