Activity › Forums › Maxon Cinema 4D › boujou c4d export prob.
Posted by Steven Dinozzi on June 30, 2008 at 7:12 pmHello all,
Really been having problems with boujou to c4d. When I import my boujou cam to c4d, c4d places the camera inside of the points aka the wrong location. In maya it works fine but i’m not comfortable in maya yet. Does anyone know why this is happening? My scene involves tracking aerial footage.
Reynaldo Duarte replied 16 years, 3 months ago 6 Members · 7 Replies -
Brian Jones
July 1, 2008 at 4:22 pmDon’t know boujou myself but a quick google search got this https://forums.creativecow.net/thread/19/861633
which might be a place to start -
Andy Stokes
November 19, 2008 at 2:09 pmHi Steven,
Did you find a solution to the problem with the point clouds being attached to the camera? I’m desperately trying to solve the same problem.
Thx,
Andy -
Katai Tang
May 19, 2009 at 7:07 pmDid anyone figure out why the export from Boujou 4.1 to Cinema 4D R10.5 problem yet? When you open the Boujou export, the C4D camera is in the middle of the point cloud and the points are attached to the camera’s movement. I even try exporting to Lightwave and got the same problem. Please let me know if there any other work around. Thanks.
Andy Stokes
May 20, 2009 at 3:39 amHey Katai,
Happy to say after lot’s of experimentation I found a solution…. Open the Boujou project from 4.1 in v4.0 and the export works fine.
Cheers,
A. -
Katai Tang
May 29, 2009 at 3:09 amIt works! I have been back and forth with C4D and Boujou tech support for 2 weeks now. Thanks for your help, Andy, I’ll share the good news with them and hope Boujou can fix that bug in 4.1.1.
Erik Eliason
March 30, 2010 at 3:28 pmI’ve been going crazy over this too.
I’m currently learning Boujou 5 and C4D 11.
How do you mean Andy, I export the camera from boujou 5 and open it in v.4, then export it to C4D again?Cheers //Erik
Reynaldo Duarte
June 5, 2010 at 8:32 pmI nearly got mad about that too but can you explain better this boujou-c4d export process?
Tks a lot,
Reynaldo
