Activity Forums Adobe After Effects bottom ticker scroll
  • bottom ticker scroll
    Posted by Tim Monaghan on June 8, 2006 at 5:18 pm
    Hello all,
    I need to build an animated bottom ticker like you see on CNN, Fox news…
    Is there a script I can write or a way to maintain a constant animated rate
    from left to right not matter how long the sentence comes out to be?
    Also, what would be the best rate for this?
    Tim Monaghan replied 20 years, 2 months ago 3 Members · 6 Replies
  • Mylenium
    June 8, 2006 at 6:07 pm
    About 50 pixels/ second is a good speed. Just create two position keyframes, then use loopOut(“continue”) for constant speed.
    Mylenium
    [Pour Myl
  • Tim Monaghan
    June 8, 2006 at 6:30 pm
    is the loopOut(“continue”) an expression that goes into
    to my position attribute?
    what does that do ?
    Thanks again!!
  • Tim Monaghan
    June 8, 2006 at 9:43 pm
    I posted a screen shot.. is this correct?
    How do I keep the speed to stay at the constant 50pixels/sec rate?
    I never really understood how to read the part I have circled…
    https://alohafilms.com/screen.jpg
  • Mike Clasby
    June 9, 2006 at 1:03 am
    For all things loopy see Dan’s tutorial “Animating a Walk Cycle”, there’s a loop project files that shows you the different loop expressions, and how to avoid pitfalls, good stuff.
    https://www.creativecow.net/show.php?page=/articles/ebberts_dan/layer_looping/index.html
  • Mike Clasby
    June 9, 2006 at 2:59 am
    loop_out(
  • Tim Monaghan
    June 9, 2006 at 6:38 am
    Thanks for this, I’ll give it a shot!
