Activity Forums Adobe Premiere Pro Both mono audio tracks not available when editing from a sequence to a sequence CS5.5
  • Both mono audio tracks not available when editing from a sequence to a sequence CS5.5
    Posted by Nathan Halder on May 15, 2014 at 4:05 pm
    Here’s what I would like to do:
    Create a sequence with one video track and two audio tracks (mono – 1 channel interview and the second channel nat sound mic).
    Put that sequence in the source window and edit from that to the timeline.
    Here’s what happens:
    No matter whether I make a mono or stereo sequence, I am unable to have audio channels 1 and 2 available to edit separately.
    On the sequence I use to edit from that is mono, I can only choose Audio 1. I can open that on the timeline and switch the A1 to track 2 but that means I need to do that every time I want to edit in a different channel to my timeline sequence?
    On the sequence I use to edit from that is stereo, I can only edit a stereo clip.
    If I put a clip in the source window, I can choose between A1 and A2 and this is what I would like to do but with a sequence!
    My footage is from an EX-1 and when I brought it into the bin, I went to Modify/Mono to the audio.
    Is this an issue with 5.5? Do I need to get 6 or CC?
    Thanks.
    Henry Tenenbaum replied 12 years, 4 months ago 2 Members · 2 Replies
  • Henry Tenenbaum
    May 18, 2014 at 9:38 pm
    Try this –
    Right click on a clip (you can do this in batches as well).
    Go to MODIFY -> AUDIO CHANNELS.
    set NUMBER OF AUDIO TRACKS to 2,
    CHANNEL FORMAT to ADAPTIVE,
    click PRESERVE CHANNEL ASSIGNMENTS,
    ACTIVE CHANNELS PER TRACK TO 1
    Set SOURCE CHANNEL LEFT to Audio 1, Ch. 1
    Set SOURCE CHANNEL RIGHT to Audio 2, Ch. 2
    Then save the preset. Don’t ask me why or how, I’m a PPr newbie myself. I do have a pretty good background in audio editing and this was driving me crazy as well. I’m sure a veteran will have a better answer.
  • Nathan Halder
    May 19, 2014 at 2:38 am
    Henry:
    Thanks so much for response. However, I think this is a fix for CS6 or CC and I have CS5.5 at the moment.
