Activity Forums Adobe Premiere Pro Boss is ON me for this shot. Have to make the “Zacuto” logo RED.
  • Boss is ON me for this shot. Have to make the “Zacuto” logo RED.
    Posted by Dane Shubert on July 13, 2021 at 1:47 am
    Please someone help!
    I don’t use resolve, so all my color has to be a lut or in the lumetri settings in premiere.
    So I have this shot that looks, well ok, but the Zacuto logo has to be red. Like RED red.
    Now, I’ve tried many ways to make this work, but I can’t seem to without making me look jaundice AF!!!
    Please, can someone help me in the color section make this shot work? I would obviously love some sort of LUT or plugin. Any tips in Lumetri?
    Thanks in advance!!!!
    Brie Clayton replied 5 years, 2 months ago 4 Members · 4 Replies
  • Blaise Douros
    July 13, 2021 at 4:56 pm
    You can do this easily in Lumetri, no need for a Resolve round trip; mask off the area you want to isolate (in this case your chest, I’m assuming?). If you move around a lot, you may need to track it–in the Effects control panel, you can draw the mask, and then use the little transport buttons that look kind of like: <| < > |> (they’re right next to the Mask Path) to track forward or backward.
    You won’t want to just crank up saturation, because that’ll make the whole mask area look different than the rest of the shot; I’d use the secondary color correction controls down toward the bottom of the Lumetri panel. Basically, this allows you to do a chroma key of the color you want to affect, then lets you apply an effect to only that keyed area. In this case, that’s the orange-y red on your shirt, yeah?
    Get that color dialed in to the Key section, then use the Correction section to add back in the more saturated red color to the area you’re keying out.
    In general, it looks like you’ve applied a somewhat desaturated treatment to this shot setup, so you may want to revisit that look–more saturated and contrasty in general will probably make the logo look more poppy, as well. Also, if the shirt itself doesn’t have a good printed ink color to start with, well…then it’s time to have your boss go have a talk with your screen print shop, no?
  • Glenn Sakatch
    July 15, 2021 at 3:15 pm
    do a search for Resolve hue vs hue and hue vs sat.
    put a window around it, and call it done
  • Blaise Douros
    July 15, 2021 at 4:06 pm
    @glennsakatch for some reason this ended up in the Resolve forum, but @daneshubert mentioned that he is in Premiere and needs to use Lumetri to accomplish this.
  • Brie Clayton
    July 15, 2021 at 6:10 pm
    Thank you Blaise! You are correct, and I’ve switched this to the proper forum.
