Activity Forums VEGAS Pro Borris FX not linked to videos after rebuild of system and new install of apps
  • Borris FX not linked to videos after rebuild of system and new install of apps
    Posted by Larry Cole on December 1, 2011 at 2:37 am
    Recently my c: drive crashed. Yes I had it backed up but due to various issues decided to do a clean install of all my software including Vegas 11 and Boris Continuum 7.0 effects package. After successfully installing all my apps, I opened up a recent project file and noted that everyone of my video tracks had lost its Borris FX. I had to re-apply each effect back to each track.
    This a fairly recent project that had a limited number of FX but if FX disappear when projects are moveed to a new PC, this is pretty scary.
    I probably should add that the effects were added in the project window to the entire video track and not to each event. The sony FX I had applied to the events seemed to stick with no problem.
    One other thought… these effects were also added via filter packages instead of individually. If I did not recreate my filter package with the same name, would it lose the effects? I was thinking filter packages would provide the default FX and then never be used again. Could it be that when a project is opened, the filter FX package is used to determine what FX to apply? If the filter package goes away then your FX go away also without even an error message?
    Has anyone else had this happen?
    Larry Cole replied 14 years, 9 months ago 2 Members · 2 Replies
  • John Rofrano
    December 1, 2011 at 2:53 pm
    [Larry Cole] “I probably should add that the effects were added in the project window to the entire video track and not to each event. The sony FX I had applied to the events seemed to stick with no problem.”
    That could be a Vegas bug. I would report it to Sony.
    [Larry Cole] “If I did not recreate my filter package with the same name, would it lose the effects? I was thinking filter packages would provide the default FX and then never be used again.”
    You are correct. The filter packages are lost once the FX are applied. I regularly do finish editing of projects and the other editors don’t have my filter packages on their PC’s and everything works fine. You may have just hit a bug with OFX being applied at the project level.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Larry Cole
    December 6, 2011 at 1:03 am
    After a little more thought, I figured out why I was losing the effects that were applied to video in the project window. When my PC was rebuilt, the drives my video were stored on were remapped to different drive letters. When the project was first opened, vegas prompted me to locate the new files. After I selected the new location, the effects disappeared. This behavior can be reproduced by just relinking any video in the project window to a new location. Definitely a bug that I will report to Sony.
