Activity Forums Boris FX BorisRed5 StandAlone Trial Version DOES NOT Render MOV Files
  • BorisRed5 StandAlone Trial Version DOES NOT Render MOV Files
    Posted by Steve on September 30, 2011 at 12:36 am
    I purchased but have not received my unlocl code for BR5. In trial version it WILL NOT render MOV files. Is this supposed to happen in trial version?
    Does this happen after the unlock code is applied? Is this a bug?
    I installed the latest version of Quicktime and all other software works on the same PC.
    Thanks for your assistance.
    Steve
    Steve replied 14 years, 11 months ago 2 Members · 4 Replies
  • Steve
    September 30, 2011 at 12:56 am
    Just activated Boris and tried to renderout a .MOV file with Transparency for a project due Sat and it failed! Guess I need to GET MY MONEY BACK!
    Steve
  • Steve
    September 30, 2011 at 3:06 am
    HELLO? ANYONE FROM BORISFX OUT THERE?
    Steve
  • Peter Mcauley
    September 30, 2011 at 1:13 pm
    Hi Steve,
    Here’s the scoop.
    The movie files that you are trying to render, .mov, rely on the Quicktime codec. Because there isn’t a 64 bit version of the Quicktime codec available, RED 5 64 bit cannot render out or read in Quicktime based files. You can however install the RED 5 32 bit version which uses the 32 bit version of Quicktime and will enable you to complete your work. You can download the 32 bit version from our web site at borisfx.com/downloads and the license that you already have will work for both 64 and 32 bit versions of the software.
    I hope this helps.
    Cheers,
    Peter.
  • Steve
    September 30, 2011 at 10:23 pm
    Peter…THANK YOU for the correct answer! You are a great person…I can now complete my client’s project and…get the check!
    Seriously, thanks, man… I was about to commit Hari Kari.
    Steve
