Activity › Forums › Boris FX › BorisRED Project back-ups?
  • BorisRED Project back-ups?
    Posted by Jaeson Koszarsky on April 24, 2010 at 3:52 pm
    I was working on a project in BorisRED4.3 and happened to have 3 comp tabs open. I usually only have one. Auto save every 5 minutes. At the end of the day I saved the project.
    When I opened it back up today, only 1 of the comp tabs was there. Argh. I assumed all 3 would be saved within the project. Boris didn’t ask if I wanted to save the others separately when I quit, like PhotoShop would if I had multiple unsaved images opened.
    Are my other comps just hidden somewhere? Does Boris store multiple copies of the auto saves that I can recover earlier work from?
    I could recreate things but I’d rather not have to start over.
    Jaeson
    Jaeson Koszarsky replied 16 years, 5 months ago 2 Members · 3 Replies
  • Matt Mullen
    April 26, 2010 at 1:58 pm
    Jaeson,
    I just did a quick test and it looks like it saves only the active Comp.
    Let me check into this and see if it is expected behavior.
    It seems like not.
    -Matt
  • Matt Mullen
    April 27, 2010 at 6:08 pm
    Jaeson,
    Do you have the project window open?
    You should see all comps in the project window you should just have to double click each comp to load a new tab in the composition window.
  • Jaeson Koszarsky
    April 27, 2010 at 6:14 pm
    I didn’t have the PROJECT window open. I just reloaded the original project, opened that window and found my hidden COMPs. Thanks.
    I ended up rebuilding my COMPs and saved the separately. But for the future, it’s good to know that everything will be saved within a single project.
    Jaeson
