Activity Forums Boris FX BorisFX Uprez & Final Cut Pro
  • BorisFX Uprez & Final Cut Pro
    Posted by Anthony Phillip on January 8, 2011 at 5:27 pm
    I’ve been demoing software for upconversion in the past few days and I’ve hit a speed bump with BorisFX UpRez. I’m currently using the 14 day trial and I’d love to try this plug-in due to its great reviews, however it hasn’t been working.
    I followed this tutorial:
    https://www.borisfx.com/videos/BCCFxPlug/Upscale.php
    I did it step by step, but when I came to the step where I apply the UpRez filter, the filter was no where to be found. All of the other BorisFX plug-ins were showing up, but the UpRez filter was missing. Its supposed to be under the ‘BCC7 Distortion and Perspective’ menu, but the only plug-in there was the ‘BCC RT Swirl’.
    I’m using Final Cut Pro 7 (Final Cut Studio 3) on an Intel Core Duo with 4GB of RAM, so my specs should be more than fine. Any ideas as to why this plug-in is not showing up in my Effects window?
    Denis Williamson replied 15 years, 5 months ago 3 Members · 4 Replies
  • Peter Mcauley
    January 10, 2011 at 2:08 pm
    Hi Anthony,
    I’d suggest that you download the very latest BCC 7 FxPlug installer and reinstall the software. It may be possible that you installed a BCC Unit, which did not include the UpRez filter and if so, that might explain the missing filter.
    Cheers,
    Peter.
    ps – if you have any questions or concerns regarding use of the filter please don’t hesitate to get in touch with me directly via email at peterm@borisfx.com
  • Denis Williamson
    April 10, 2011 at 3:24 am
    Peter,
    As a new downloader of UpRez I’ve been unable to get it to work in FCP 7 as the tutorial mentioned by Anthony (above) is no longer available (at least not at that url).
    I’m trying to uprez a regular PAL DV clip, which doesn’t have square pixels, so I can’t use the HD Slug method, but the alternative directions in the help doc are fairly meaningless (“unanimated BCC Generator”???).
    Is there a video tutorial available anywhere…?
    Regards
    denisw
  • Peter Mcauley
    April 19, 2011 at 8:05 pm
    Hi Denis,
    Sorry, the tutorial that you mention was removed and at this time we don’t have a replacement. Here’s how to us the filter:
    • place a clip in the timeline that is of the same size as the final result that you need – the content of the clip is irrelevant as we are only using it for size
    • apply the uprez filter to this clip
    • double click on the filtered clip to access the filter controls
    • drag the media to be uprezzed into the well layer
    • then just adjust the controls until you are satisfied with the result
    I hope this helps but if it’s not clear please let me know and I’ll have a video created for you (or I’ll create one for you myself) which I’ll then send directly to you.
    Cheers,
    Peter.
  • Denis Williamson
    April 23, 2011 at 3:27 am
    Thanks for the information, Peter, I’ll try it out as soon as I get a minute. One unfortunate thing is that UpRez was a MacUpdate special recently (50% off – but only for 24 hours) which is what brought me to BorisFX in the first place. Don’t worry though, if I like UpRez enough I’ll find a way to buy it.
    Regards,
    Denis
