Activity › Forums › Boris FX › Borisfx optical stabilizer will not analyse clip
  • Borisfx optical stabilizer will not analyse clip
    Posted by Alistair Ruane on February 23, 2010 at 11:32 am
    Hello,
    I have a problem with the borisfx image stabilizer in FCP 5. I import my clip onto the timeline and apply the stabilizer filter to it. Then double click the viewer and move to the filters tab where I drag the source clip into the well. At this point i think I am supposed to click analysze and then I can move on the adjusting perameters. However nothing happens when I press analyze and the image in the viewer is blank and only the sound comes through. So I can’t see what effect any perameter changes might have or indeed if the plugin has any efect at all. I am runnning FCP 5 on OSx 10.5.8 on a powermas G5. Please help.
    Regards
    Alistair
    When facing a difficult task act as if it’s impossible to fail – If you are going after Moby Dick take the tartar sauce.
    Matt Mullen replied 16 years, 7 months ago 2 Members · 5 Replies
  • Matt Mullen
    February 23, 2010 at 6:44 pm
    What version of BCC are you using?
    What is your RT setting in FCP?
  • Alistair Ruane
    February 23, 2010 at 7:13 pm
    Thanks for responding Matthew. I am using BCC6 Optical Stabilizer Demo at the moment. I am new to all of this and downloaded it with a view to buying it later. My RT settings if I understand the question are that Filters, Frame Blending and Motion Blur are ticked. Frame rate is 100% and Resolution is at 100% and the video processing is set to render in 8 bit YUV.
    Regards
    Alistair
  • Matt Mullen
    February 24, 2010 at 7:51 pm
    What is the exact version of Final Cut?
    Is the Mode menu in the filter set to Stabilize or Smooth?
    -Matt
  • Alistair Ruane
    February 24, 2010 at 9:23 pm
    Hi Matt,
    The version of final cut is 5.1.4 and I have tried the mode setting in both stabilize and smooth modes and in either case when I click the analyze button nothing happens. Any ideas?
    Alistair
  • Matt Mullen
    February 24, 2010 at 10:16 pm
    BCC 6 is qualified for FCP 6 and 7.
    Let me try to do some testing to see if I can get it to work or not on 5.
    What is your OS and processor on the machine.
    -Matt
