borisfx 6 for FCP
Posted by Dan Luke on June 9, 2009 at 2:35 amWhere is 3d extruded text in the bcc6 upgrade?
Peter Mcauley replied 17 years, 3 months ago 2 Members · 4 Replies -
Peter Mcauley
June 9, 2009 at 1:08 pmHi,
You’ll find that in the 3D Objects category of filters. If you have downloaded the trial and do not see the filters in FCP then you need to make sure that your system meets the minimum requirements. First, and foremost, it must be an Intel based Mac. And secondly, you must be running Leopard.
Hope this helps!
Cheers,
Peter.
Peter Mcauley
June 9, 2009 at 3:13 pmHi Dan,
Only the 3D Objects category of filters require a MacIntel processor, however, the included Boris “BCP” filters require Leopard but can run on machines equipped with the PowerPC chip.
• With MacIntel processor and Leopard OS all of the BCC 6 filters are available.
• With PowerPC processor and Leopard OS all except for 3D Objects filters are available
• With PowerPC processor and Tiger OS, all except for 3D Objects and BCP filters are availableI hope this helps.
Cheers,
Peter.
