Activity › Forums › Boris FX › BorisCC5 & CS4
  • Peter Mcauley
    October 26, 2008 at 8:39 pm
    Hi Tudor,
    You should make sure that the filters are in the CS4 MediaCore folder. IF they are not then, then you can manually move them into this folder and the filters should be available upon the next launch of AE / Premiere Pro. If you are still having problems then you should send an email off to support@borisfx.com and someone will assist you in getting the filters to show up.
    Cheers,
    Peter.
