Activity Forums Boris FX Boris XML Transfer
  • Boris XML Transfer
    Posted by Adam Wise on March 3, 2011 at 7:07 pm
    When I use XML Transfer to export my timeline, the timeline gets messed up. The clips stay in the order they were in from the FCP timeline, but the in and out points of the clips are messed up and there are long sections of black in between clips where simple default cross dissolves used to be.
    I am not using subclips. Each file is its own quicktime file.
    Please, if you need more info, ask!
    Mac Pro 8 core
    8GB Ram
    FCP 7.0.3
    AE CS5
    Boris XML Transfer 2.2
    Itamar Naamani replied 15 years, 4 months ago 3 Members · 4 Replies
  • Boris Yamnitsky
    March 3, 2011 at 7:33 pm
    We’ll need to see your XML file to be sure. Can you email it to me at boris@borisfx.com?
    Boris Yamnitsky
    BorisFX
  • Itamar Naamani
    May 23, 2011 at 5:39 am
    Ever found out what the problem was? I’ve experienced a similar problem.
  • Adam Wise
    May 23, 2011 at 2:20 pm
    Nope, I sent off the information and never heard back.
  • Itamar Naamani
    May 24, 2011 at 7:29 am
    Thanks for the response!
    I solved it here. The sequence was a 50fps imx sequence. The shift in in- \out- points happens when Boris converts it to a 25fps sequence (in my case). When setting the Boris import settings to 50 fps it imports fine.
