Activity Forums Boris FX Boris Transitions won’t work! Halp!!!
  • Boris Transitions won’t work! Halp!!!
    Posted by Matt Mages on June 22, 2014 at 11:17 pm
    Why can I not add transitions between clips with Boris CC9 and Premiere Pro CS6? It will not let me drag the effect across two clips.
    Eugene replied 11 years, 8 months ago 3 Members · 2 Replies
  • James Macon
    June 23, 2014 at 3:42 pm
    Hi Matt-
    Our single track transitions are enabled in Adobe CC and on. They are not supported in CS6.
    James
  • Eugene
    December 24, 2014 at 8:55 pm
    I have a another question. If I have a filter on the incoming clip, after the transition is over or near over, the first frame of the incoming clip is without the filter effect, then the effect suddenly shows thereafter. Is there any setting to adjust for this?
    Eugene
