Activity Forums Boris FX Boris Transfer AE & Avid Time warps
  • Boris Transfer AE & Avid Time warps
    Posted by Nic Coe on August 23, 2011 at 7:31 am
    I am trying to get an AAF sequence from avid through to AE CS5.5 using Boris AE Transfer 3.0.4.
    The sequence has a lot of timewarp/speed ramp effects in it. It seems that wherever there are keyframes in the speed ramp the sequence will match correctly but in between the keyframes the frames are not aligning correctly.
    Is this possible or does the problem translating speed ramp keyframes/bezier curves between FCP and AE also apply for AVID to AE?
    ta
    Nic
    Boris Yamnitsky replied 15 years ago 2 Members · 1 Reply
  • Boris Yamnitsky
    August 26, 2011 at 12:45 pm
    Nic,
    The three apps – Avid, FCP and AE – all have different keyframe interpolation formula. Although we do our best to match the curve, sometimes you will need to manually adjust the parameters to achieve a perfect match.
    Boris Yamnitsky
    BorisFX
