Activity Forums Apple Final Cut Pro Legacy Boris Title Roll Flickers
  • Boris Title Roll Flickers
    Posted by Glenn Miers on September 1, 2009 at 2:51 am
    Hi All,
    When using Final Cut 7 & Boris Title Crawl generator to create a credit roll I get flickering text upon output to DVD & my production monitor via decklink HD Extreme. When I use exactly the same settings in Final Cut Pro 6 there is no flickering. Has someone else run into this problem, or has something changed within FCP7 that would cause this affect?
    I have enabled the deflicker option in Boris (which I do in FCP6 anyway) but it still flickers.
    Erik Mickelson replied 17 years ago 3 Members · 2 Replies
  • David Bogie
    September 1, 2009 at 5:50 pm
    All I can tell you is, yes, something fundamental has changed in the Boris titlers between 6 and 7. I can see it on my machine. Regardless of my field and render settings, Boris seems to only render as progressive.
    There have been other posts on other FCP forums but no one has reported any contact with Boris.
    bogiesan
  • Erik Mickelson
    September 1, 2009 at 6:46 pm
    Yep, my last DVD the titles (made with the Boris titler) looked pretty poor! No/low paying job and the client was ecstatic that there were titles and chapter markers for skipping around on the DVD!
    MacPro Dual Core2Duo 3.0Ghz, 6GB ram, 4TB SATA Raid, Snow Leopard 10.6, FCPStudio 3, QT X
