Activity Forums Apple Final Cut Pro Legacy Boris Title 3d rendering glitch
  • Boris Title 3d rendering glitch
    Posted by Ben Trahair on August 19, 2008 at 11:02 am
    Hi All,
    I’ve had a look through the past forums but haven’t been able to find anyone suffering from this exact issue.
    We’re using the inbuilt Boris Title 3d tool that ships with FCP studio 2. The machine is new and has only ever had FCP studio 2 installed. Its running on an intel based 2 x 2.8 Quad core Mac with 8 gigs of ram and OSX 10.5.4. FCP version 6.0.4
    The issue is that the Boris Title 3d tool which we are using for titling has problems maintaining paragraph justification through a render – frequently when we render a sequence within FCP the justification will strangely move to centre when it has been set to left – or vice versa. The only way to fix the problem is to open the plugin again, close it, re-render and check that the justification is correct.
    We are producing lots of text driven content so its becoming less and less of a viable work around to go this way. Does anyone know if there is any solution to the problem?
    Ben
    Ben Trahair
    http://www.bentrahair.com
    Ben Trahair replied 18 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
