Activity Forums Apple Final Cut Pro Legacy Boris Title 3D problems
  • Boris Title 3D problems
    Posted by Max Frank on June 5, 2008 at 10:17 pm
    I did a search and haven’t been able to find a solution yet.
    I edited a feature-length documentary with a gazillion titles and subtitles in FCP 4.5 using Boris Title 3D.
    As many of you know, after the subsequent upgrades, when I open that old project, the Boris Title 3D’s formatting comes out all wrong, the kerning and leading look completely different, etc etc etc.
    I’ve tried trashing the Boris prefs, and re-installing Calligraphy version 1.1 from:
    https://docs.info.apple.com/article.html?artnum=120118
    But the problem still persists.
    Any ideas?
    I’m running the following:
    FCP 6.0.3
    10.5.2
    MacBook Pro Dual 2ghz
    Wayne
    David Bogie replied 17 years, 11 months ago 2 Members · 1 Reply
  • David Bogie
    June 6, 2008 at 3:15 pm
    Contact Boris.
    if that doesn’t help, and I do not think they will be able to help, your only choice is to redo everything.
    I’d prepare for the worst case scenario and I’d work in an application that doesn’t have the same poor reputation for failure after upgrades.
    bogiesan
