Activity Forums Boris FX Boris Title 3D kerning problem – Again
  • Boris Title 3D kerning problem – Again
    Posted by Eric Holzapfel on April 6, 2012 at 12:56 am
    Hello All,
    I thought I would try this first. I am constantly having problems with kerning trying to
    use Boris Title 3D that come along with FCP 7 (I have version 7.0.3).
    I have tried deleting the pref for the Boris Title 3D – w/o trashing FCP 7 prefs.
    No dice. I have tried trashing the prefs for FCP 7. That “almost” worked.
    I opened FCP w/o setting the appropriate prefs (disks, tracks, etc, etc).
    Opened a new project – standard 640×480 ntsc. added a slug to the timeline,
    and then placed a boris title 3d on the video track above my slug. I then proceeded to
    two lines of text, each in a different font – the kerning was fine.
    I then restored my FCP prefs, opened the same project – added a second slug to the timeline, and a
    second Boris Title 3D – and tried entering more text – same or diff fonts – the kerning is way off.
    So something is weird here. I do like the elements of the plug-in – but I have been adjusting
    the kerning manually – this does not cut it.
    Can anyone offer any suggestions here? I am using Intel platform – with OS – Lion – my system is about 4 months old.
    Eric
    Final Cut Pro, Adobe After Effects, Photoshop
    Eric Holzapfel replied 14 years, 4 months ago 3 Members · 3 Replies
  • Peter Mcauley
    April 6, 2012 at 1:25 pm
    Hi Eric,
    This is the first time that I’ve heard of such a problem with using Title 3D in FCP so I don’t have any first hand knowledge that I can fall back on which might have solved the issue for you. With that, I’d like to suggest that you contact someone in our support group who can help you with this. You can reach them via email or phone:
    support@borisfx.com
    888 772 6747
    Cheers,
    Peter.
  • Jeremy Ellis
    April 6, 2012 at 2:48 pm
    Hello Eric,
    Is it possible for you to send me a copy of a project file for FCP that you are seeing this in? Please send it to jeremye@borisfx.com
    Thank You
    Jeremy
    Boris Support
  • Eric Holzapfel
    April 7, 2012 at 4:06 am
    Hello Jeremy,
    will do. Just checked in tonight late CA time.
    Eric
