Activity › Forums › Apple Final Cut Pro Legacy › Boris Title 3d Flickering in Final Cut 7
Posted by Benjamin Asnis on January 5, 2010 at 3:29 pmHi,
I’m using Final Cut Pro 7 and have noticed that Boris Title 3d flickers on scrolling text. It used to work perfect in prior versions in terms of flickering. For instance when I render the same old project that I had created Final Cut 6 (and had worked fine) it now flickers in final cut 7. Has anyone else experienced this?
Ben
Jacek Kropinski replied 16 years, 4 months ago 6 Members · 10 Replies -
David Bogie
January 5, 2010 at 4:09 pmUnfortunately, this is a known issue. You can search here for similar threads but I do not recall any solutions being offered. I’ve stopped using most of the Boris plugs.
bogiesan
Kevin Monahan
January 5, 2010 at 5:34 pmWhat’s the format? How long is the roll?
David, do you use only Motion for text now? I still use Boris for down and dirty.Kevin Monahan
60 Blu-ray Templates for Final Cut Studio 2009
http://www.fcpworld.com
Author – Motion Graphics and Effects in Final Cut Pro -
Benjamin Asnis
January 5, 2010 at 5:55 pmHi,
Thanks for the replies. The format I’m using is HDTV 1080i 59.94 – Uncompressed 8 bit. The credit roll I’m dealing with is around 30 seconds or so nothing too fast, and in the past it worked great.
Ben
David Bogie
January 5, 2010 at 7:18 pm[Kevin Monahan] ”
“My down and dirty text is just built with the regular text tools in FCP. Anything with any elegance is done in Motion.
I still loathe Motion.The boris text movement tools no longer seem to create fields and the sub-pixel interpolation seems to have been rounded off to whole pixels. It’s a mess and no one at apple or Boris is admitting it’s a problem. Lots of us just stopped seeing Boris in the menu for text objects; it’s invisible, sort of, since it’s useless.
bogiesan
Boris Yamnitsky
January 5, 2010 at 10:43 pmFirst let me acknowledge the problem. It first appeared in FCP7. We believe it was fixed in FCP 7.01. Please check which minor version of FCP you are on and see if an update solves the problem.
Sorry for trouble,
Boris Yamnitsky
BorisFX -
Kevin Monahan
January 6, 2010 at 7:35 amThank you Boris! Dave, sorry you don’t love Motion, I do. But then again, I’ve spent a lot of time living in it. It’s got some damn cool stuff in Motion 4 you simply can’t ignore.
I forgot to mention that Motion 4 has a cool Behavior for rolling titles called “Scroll Text” which works like butter. Check it out.
Kevin Monahan
Benjamin Asnis
January 11, 2010 at 3:00 pmHi Boris,
Thank you, the update solved the flicker problem.
Ben
Fauzul Pandjaitan
April 23, 2010 at 3:12 pmCould you please share the link to the update or could you please email me to adzimap@yahoo.com thx…
Benjamin Asnis
April 24, 2010 at 2:42 am -
Jacek Kropinski
May 26, 2010 at 7:55 pmNo, the problem persists, even in FCP7.02 – completely random flickering of entire or single characters within a line. These are completely static graphics.
I have just inherited to fix a very complicate 28:30 timeline, riddled with Boris 3D text graphics.
You can break the render, re-render and it will stop flickering in that spot but move somewhere else. To replace all the graphics would probably take a week. Grrrrrrrrrrrrrrrr on Boris and Final Cut. Please provide a solution!
