Activity Forums Apple Final Cut Pro Legacy Boris Text Generator Missing in FCP 6.0.2
  • Boris Text Generator Missing in FCP 6.0.2
    Posted by Paul Bundock on February 29, 2008 at 11:18 am
    Recently upgraded to FCPS 6.0.2 and now find the Boris Text Generator is missing. Only FCP text is available. Boris was there in FCP 6.0.1! Can anyone shed any light on this for me?
    Is there something I’m not doing? or have they moved or removed it all together?
    Many Thanks,
    Paul
    Kim Rowley replied 18 years, 6 months ago 6 Members · 10 Replies
  • 10 Replies
  • Walter Biscardi
    February 29, 2008 at 1:41 pm
    it should still be in the same place. Viewer > Boris > Title 3D. It is on all three of our systems running 6.0.2.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR
    The new Color Training DVD now available from the Creative Cow!
    Read my Blog!
  • Paul Bundock
    February 29, 2008 at 2:05 pm
    Boris isn’t there. I checked with a friend who also upgraded and the same thing has happened to him.
    Quicktime 7.4 update has caused this. It seems this update broke a no. of things including Boris plug-ins. It has lost the bundle flags so are not being recognised by FCP.
    You can download the calligraphy plugins for free and then copy the Title 3D Bundle and Title Crawl.bundle files into your plugins folder, overwriting the exisiting ones.
    https://www.borisfx.com/download_files/CalligraphyForFCP.dmg
    This will fix any problems.
    Paul
  • Walter Biscardi
    February 29, 2008 at 2:10 pm
    [Paul Bundock] “Quicktime 7.4 update has caused this.”
    We never downloaded QT 7.4. We went from 7.3.1 to 7.4.1. 7.4 caused a myriad of issues.
    Read my Blog!
  • Paul Bundock
    February 29, 2008 at 2:21 pm
    yea we didn’t either download QT 7.4 either.
    We also went the same path as you, straight to QT 7.4.1. and this is when it happened.
  • Warren Eig
    February 29, 2008 at 4:47 pm
    This happened here in Tiger but when I put in another drive and rebuilt the system to Leopard I didn’t encounter this problem. Might be Tiger specific.
    Warren
    Warren Eig
    O 310-470-0905
    email: warren@babyboompictures.com
    website: https://www.babyboompictures.com
    https://www.atomfilms.com/af/content/knitwits
    https://www.atomfilms.com/film/family_xmas.jsp
  • David Roth weiss
    February 29, 2008 at 4:56 pm
    [Paul Bundock] “Quicktime 7.4 update has caused this. It seems this update broke a no. of things including Boris plug-ins.”
    Actually, the Boris dissapearing problem was caused by running the updater while FCP was open.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Business & Marketing, and Indie Film & Documentary forums.
  • Warren Eig
    February 29, 2008 at 6:19 pm
    [David Roth Weiss] “Actually, the Boris dissapearing problem was caused by running the updater while FCP was open.
    David, I didn’t have FCP open when I updated. It did happen on two machines running Tiger though.
    Warren
    Warren Eig
    O 310-470-0905
  • David Roth weiss
    February 29, 2008 at 6:57 pm
    [Warren Eig] “David, I didn’t have FCP open when I updated. It did happen on two machines running Tiger though.”
    Must have been a coincidence then, because all of the people I helped out of that jam had in fact left FCP running.
    David Roth Weiss
    Director/Editor
    Los Angeles
  • Chris Poisson
    March 1, 2008 at 1:32 pm
    In some cases with some of the recent updates, Boris goes into it’s own folder in the generator pull down, look for “Boris.” It may be in there.
    Have a wonderful day.
  • Kim Rowley
    March 3, 2008 at 10:19 am
    Hey Paul,
    this happened to me too. Got the following solution from Boris support. Fixed the issue immediately.
    Note: the link at the end doesn’t work if you use Firefox. Access it from Safari.
    Here’s the long and the short of it. The four bundle files that make up the
    Boris titling application called Calligraphy rely on the operating system to
    flag them as bundles instead of folders. In some cases (like if you update
    FCP or your OS) these bundles get mislabeled as folders, therefore FCP can
    not “see” them and you loose your titles. The fix for this is simple. Below
    is a link to where you can download a set of new bundle files that identify
    themselves as bundles. Once you’ve downloaded them, locate the FCP plugins
    folders here: Hard Drive>Library>Application Support>Final Cut Pro System
    Support>Plugins. In there you should find the four FOLDERS named: “Text
    Scrambler.bundle”, “Title 3D.bundle”, “Title Crawl.bundle” and “Vector
    Shape.bundle”. Delete those FOLDERS and replace them with the FILES you just
    downloaded.
    That’s it.
    Please let me know if this helped or if you have any other questions.
    Dual 2.7 GHz G5, 4GB RAM, ATI Radeon 9650, Xserve RAID, AJA IO, 2 20″ Cinema Display, FCP Studio 2 (6.02), OS X10.4.11
