Activity Forums Boris FX Boris red t/C window dub
  • Boris red t/C window dub
    Posted by Ben Strasser on July 23, 2009 at 3:25 am
    Does anyone know if there is away to produce a T/C window dub with Red?
    Using legacy M100ixs lastest Boris Red.
    BBBBBBBen.
    Peter Mcauley replied 17 years, 2 months ago 2 Members · 1 Reply
  • Peter Mcauley
    July 23, 2009 at 11:18 am
    Hi Ben,
    You can use RED to generate timecode alright, but it cannot read any metadata from the host.
    To use RED to generate timecode, add a text track – you can do this by selecting the text tool from the toolbar and then clicking on the comp window. Then select the face sub-track of the text track – this should happen automatically. In the Controls Window, click on the Generator tab and select Timecode from the Generator Type pop-up.
    Hope this helps,
    Peter.
