Activity › Forums › Boris FX › Boris Red Standalone on External Monitor
  • Boris Red Standalone on External Monitor
    Posted by Mike Steinberg on August 15, 2008 at 7:16 pm
    I have Boris Red 2.0 running on a Mac with Media 100i (version 7.5.1) with two computer screens and one external broadcast(preview) monitor.
    I can see Boris Red 2.0 on the preview monitor if I open Boris Red 2.0 through Media100. However, how do I see Boris Red 2.0 on the preview monitor if I open it as a standalone engine?
    The the first three options on the Preview Menu are greyed out.
    Thanks very much,
    Mike
    Peter Mcauley replied 18 years, 1 month ago 2 Members · 1 Reply
  • Peter Mcauley
    August 25, 2008 at 12:39 pm
    You should be able to have a video feed from RED to the broadcast field monitor via the firewire out option. Open up the preferences pane (Edit>Preferences) and go to the preview tab. Then set the External Monitor Output to Firewire. Then close the preferences pane and select Preview>Connect to External Monitor and you should be all set.
    Cheers,
    Peter.
