Activity › Forums › Boris FX › Boris RED on Vista 64?
  • Matt Mullen
    July 8, 2009 at 4:15 pm
    Norman,
    Red will install and work in Vista 64 but runs as a 32 bit application.
    It will not work with Vegas if you are running the 64 bit version.
    If you have the 32 bit version of Vegas installed you should be able to run as a plug-in there. If not you could run Red as a standalone and export your clips to later import into Vegas.
    Hope this helps.
    If you have further questions or concerns feel free to e-mail boris support at support@borisfx.com or by calling us at 888-772-6747
  • Norman Willis
    July 8, 2009 at 10:01 pm
    Matthew,
    Thank you.
    Norman Willis
    http://www.nazareneisrael.org
    servant@nazareneisrael.org
