Activity Forums Boris FX Boris Red crashes in this situation…
  • Boris Red crashes in this situation…
    Posted by Axel Andy on June 3, 2007 at 7:47 pm
    After I import an eps file then try to export as an “swf” file the system crashes. It only crashes with the eps files. I haven’t had a problem exporting swf’s that were made with other files.
    I have to use the stand alone engine for this because I need my composition size to be 180×135 pixels. If I launch from the host I can’t change the dimmensions.
    Peter Mcauley replied 19 years, 2 months ago 2 Members · 3 Replies
  • Peter Mcauley
    June 5, 2007 at 3:37 pm
    What platform are you on? Have you tried converting the imported EPS file to splines to see if that bypasses the crash that you are seeing? Can you send me a copy of the EPS file? If so then please zip it and send it to me at petrem@borisfx.com.
    Cheers,
    Peter.
  • Axel Andy
    June 7, 2007 at 1:24 pm
    Hi Peter…
    When using the 3.04 version of the stand alone engine it crashes on import of eps files. So I tried launching my older 3.0 version and had absolutely no problems. I’ll come back to this problem later. Right now I need to figure out an effect for a job I’m doing. Could you check out me recent posting regarding a “sparkle/light flash” effect?
    K
  • Peter Mcauley
    June 14, 2007 at 3:48 pm
    Hi Kay,
    Feel free to contact me directly regarding any issue that you may encounter when using RED. My email address is peterm@borisfx.com. There may be something system specific that is causing this error – can you please send me your system specs? Perhaps you could also send me the EPS file that is causing the crash and I’ll give it a go here.
    Cheers,
    Peter.
