Activity Forums Boris FX Boris Red and AE plugin
  • Boris Red and AE plugin
    Posted by Jean-luc Vervenne on July 15, 2011 at 4:25 pm
    Hi Everybody,
    I have Red5 with Sony Vegas and have read that AE plugin would work in red5.
    Does that mean that if I have Magic Bullet 2 for AE I can use it from within Red5 ?
    Where do I need to look in red5 to start to use/find the AE plugin ?
    Any place wher this is ‘documented’
    Thanks for any explanation/help you can provide.
    Peter Mcauley replied 15 years, 1 month ago 2 Members · 3 Replies
  • Peter Mcauley
    July 15, 2011 at 7:31 pm
    This filter has not been tested with RED 5 but if you want to try that, you will need to place the filter here:
    64 bit:
    c\Program FIles\Boris FX, Inc\BorisPlugins5Common64
    32 bit
    c\Program FIles\Boris FX, Inc\BorisPlugins5Common32
    I hope this helps,
    Peter.
  • Jean-luc Vervenne
    July 15, 2011 at 8:45 pm
    Thanks I’ve done that and now I see in the filter the “red giant plugin” but no luck as it crashed Vegas.
    Would it be possible to have a list of the AE plugins that have been tested with vegas and that seem to work ?
  • Peter Mcauley
    July 15, 2011 at 8:51 pm
    The only plug-ins that have been tested with RED 5 in the Sony Vegas Pro host in our labs and are known to operate as expected are BCC 7 and FEC 5.
    Cheers,
    Peter.
