Activity Forums Boris FX Boris red
  • Boris red
    Posted by Bart Molen on September 19, 2011 at 12:37 am
    Hello
    I’m using Boris Graffiti with Corel VideoStudio, would like to know if I could also use Boris red. If its not possible can Boris Red be used as stand alone?
    Bart Molen replied 14 years, 11 months ago 2 Members · 2 Replies
  • Jon Kozenko
    September 19, 2011 at 10:01 pm
    Bart,
    Unfortunately, RED will not work directly with Corel VideoStudio, but yes, RED can be used as a stand-alone program (in RED’s case it’s called the ‘Engine’). You can use RED stand-alone to import/export media between itself and Corel. I would recommend downloading the trial version to see how the import/export workflow works for you – the trial does not have any import/export limitations, so you can run full tests with the trial version.
  • Bart Molen
    September 19, 2011 at 11:30 pm
    Thanks for the reply, will try the trail version first.
