Activity Forums Boris FX Boris red 5 – Vegas pro 11 – Eon Fusion 6
  • Boris red 5 – Vegas pro 11 – Eon Fusion 6
    Posted by Guenal Jean-luc on June 7, 2012 at 3:47 pm
    Hello from France,
    I install Boris Red 5.1.5 trial in Vegas Pro. it works.
    But my Eon Fusion 6 can not be run, since the installation of Boris Red.
    Do you know this problem ?
    thank you
    Guenal Jean-luc replied 14 years, 2 months ago 3 Members · 6 Replies
  • Boris Yamnitsky
    June 7, 2012 at 4:44 pm
    We’ve not seen this problem but then, we do not run Vegas and Fusion on the same machine. I’ll have our support team investigate your problem.
    Boris Yamnitsky
    BorisFX
  • Guenal Jean-luc
    June 7, 2012 at 5:35 pm
    Thank you so much Boris,
    I seem to recall that BCC7 Trial posed the same problem because OFX settled in Common files… but I’am not sure.
    Jean-Luc
  • Jeremy Ellis
    June 7, 2012 at 6:09 pm
    Jean-Luc,
    You are correct and that is most likely the issue. The Red installer defaults to installing to:
    C:/Program Files/CommonFiles/OFX/Plugins
    If you uninstall and reinstall and change that to:
    C:/Program Files/Sony/Vegas Pro 10.0/OFX Video Plugins
    that should correct the problem. Please let me know if that works.
    Thank You
    Jeremy
    Boris Support
  • Guenal Jean-luc
    June 7, 2012 at 10:17 pm
    Jeremy,
    I installed in C :/ Program Files / Sony / Vegas Pro 11.0/OFX Video Plugins.
    But I found a file in: Program / ​​OFX / Plugins / BorisRed.ofx.bundle / contents / Win 64/BorisRED.ofx
    Eyeon Fusion displays that can not start because of this.
    Is it possible to move “BorisRed.ofx” ?
    Jean-Luc
  • Jeremy Ellis
    June 8, 2012 at 2:44 pm
    If that file is in the Common Files folder than yes you would want to remove that and only have it in the Sony specific folder.
    Thank You
    Jeremy
    Boris Support
  • Guenal Jean-luc
    June 12, 2012 at 5:10 pm
    Jeremy,
    I moved the folder in : Vegas Pro Video 11.0 / OFX Plugins / BorisRed.ofx.bundle / contents / Win 64/BorisRED.ofx.
    Boris Red and Vegas Pro 11 work.
    But Eyeon Fusion does not start.
