Activity Forums Boris FX Boris Red 5 doesnt install correctly in Premiere Pro 5.5
  • Boris Red 5 doesnt install correctly in Premiere Pro 5.5
    Posted by Tom Daigon on July 17, 2011 at 12:01 pm
    I recently purchased Red 5 for use with Premiere Pro CS 5.5. I am very disappointed that the installer included with the most current version of Boris Red 5 (MAC ) only has an installer for Premiere Pro CS4. It didn’t get installed correctly since it does not show up in the effects window in PrP. Most other vendors have a special installer to deal with the CS 5.5 issue. Anybody know a workaround to fix this dysfunctional installer ?
    Tom Daigon
    Avid DS / PrP / After Effects Editor
    http://www.hdshotsandcuts.com
    Peter Mcauley replied 15 years, 2 months ago 2 Members · 1 Reply
  • Peter Mcauley
    July 18, 2011 at 1:01 pm
    Hi Tom,
    The reason for this is that RED 5 in it’s current incarnation is not built to run in 64 bit applications on the Mac platform. On Windows this work has been done and RED installs and operates as expected in that environment, but the Mac port remains a work in progress. Having said that, the work is close to completion and once it is ready, you will be able to install and operate RED 5 on Mac CS 5 +. I hope this helps explain the situation.
    Peter.
