Activity Forums Boris FX Boris red 4.2 Applying Transitions
  • Boris red 4.2 Applying Transitions
    Posted by Elie Mosseri on February 13, 2008 at 8:03 pm
    I am using FCP 2 on a G5 2.7 and i am applying a boris red 4.2 transition effect between 2 clips on V2 when i open the effect in Boris to modify that works fine. My problem is when i Apply the effect and go back to FCP the transition eliminates V1 for the duration of the effect and then V1 comes back after the transition is done.
    Elie Mosseri replied 18 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
