Activity Forums Boris FX Boris Red 4.1 Frame Problem in Sony Vegas 7
  • Boris Red 4.1 Frame Problem in Sony Vegas 7
    Posted by Accountclosed on May 13, 2007 at 4:43 pm
    Static Generator for Vegas 7 by Boris Red 4…
    Whenver i use it on my Timline and go inside the Boris Red 4 Confused
    Look at this ??
    i can’t increase / decrease the duration time even from Red’s control panel..
    guess what on spot at vegas timeline its duration is 09.29
    and inside i got boris is only one frame…
    can’t change it or anything with duration….
    what should i have to do to increase the frames or duration of the spot in Boris Red 4.1??
    Peter Mcauley replied 19 years, 4 months ago 2 Members · 1 Reply
  • Peter Mcauley
    May 14, 2007 at 5:55 pm
    Hello,
    You are not seeing any animation because this is a Static effect, with a duration of 1 frame only. If you would like to change the length of the effect you may do so by applying the filter to an Empty Event in the Vegas timeline. You set the length of the Empty Event and then add the RED filter to this track.
    I hope this helps.
    Cheers,
    Peter.
