Activity Forums Boris FX Boris Red 4 composite window
  • Boris Red 4 composite window
    Posted by Sojrn333 on December 31, 2006 at 7:11 am
    When I open Boris Red 4 in Adobe Premeire Pro 1.5.1, everything comes up except the composite window. What happens is the record window in APP is framed by the outer edges of the composite window. Nothing can be done with the media. Other than that BR4 is fine when used alone. Any help would be appreciated.
    Sojrn333 replied 19 years, 8 months ago 2 Members · 2 Replies
  • Paul Fx
    January 3, 2007 at 4:03 pm
    Sojrn333, check your email, I sent you some instructions.
    Paul
  • Sojrn333
    January 3, 2007 at 6:52 pm
    Thanks for the help Paul. (email hasn’t arrived yet) I finally heard from Boris and it turned out that the openGL had to be turned off. One other question for you, the tutorial that came with it is for Red 3GL and it shows that whatever is in the NLE timeline window is supposed to come up in the Boris composite window when it’s opened from the NLE. Is this the case?
