Activity Forums Boris FX Boris Red 3.02 GL copy paste
  • Boris Red 3.02 GL copy paste
    Posted by Joseph Mehr on September 20, 2005 at 10:36 pm
    Boris Red 3.02 GL Avid Xpress 5.1.6
    Sometimes the copy paste functiun does NOT work for some keyframes, I can’t figure out why !
    For example, I copy a keyframe, I paste sowewhere else in the timeline, the original values are NOT pasted, Is there a setting I ignore ?
    Many thanks for answer.
    Ted Levy replied 20 years, 11 months ago 4 Members · 5 Replies
  • Joseph Mehr
    September 24, 2005 at 12:59 pm
    Is anybody home ?
  • Mark Frazier
    September 26, 2005 at 6:45 pm
    I’ve only had this issue when attempting to paste multiple keyframes at a time, or a keyframe with a lot of different attributes. Are you attempting single keyframes or multiples? Also, what kind of track(s) are you working in? (Position, filter, etc.) How many atributes are contained within the keyframe? Since there’s been no responses so far, possibly a more detailed description of the problem will help figure it out.
  • Scott Fisher
    September 26, 2005 at 11:13 pm
    If you want to send me the project file sans media and point out the offending keyframe, I can troubleshoot it for you.
    my e-mail is:
    advres (at) gmail (dot) com
  • Joseph Mehr
    September 28, 2005 at 2:12 pm
    Many thanks for answers !
    Mark !
    This happened to me specially (and recently) on title keyframe, and sometimes in other situations !
    Advres !
    Thanks, I’ll send you the project as soon as I am back to the studio
  • Ted Levy
    October 3, 2005 at 5:53 am
    This has been my biggest issue with Boris. I have the problem in Boris FX7, most often when copying and pasting keyframes of Spline Objects. Not only doesn’t the copy/paste work correctly with Splines, but it inadvertantly modifies other keyframes that shouldn’t be affected, and sometimes adds extra unwanted keyframes that then behave bizarrely. I sent a file to Boris and they confirmed the issue months ago but thay have done nothing to fix the problem. In trying to create animated masks with Spline Object, it becomes a major problem.
    Ted
