Boris RED
Posted by Rs3 Prod on June 21, 2006 at 3:27 amPlease Help. Does Boris RED 3.0.5 work with FCP 5.1.1?????? Well I know it doesn’t but is Boris working on a patch?????
Rick Simpson
RS3Productions
Pensacola, Fl
http://www.web.mac.com/saleen281Paul Fx replied 20 years, 3 months ago 4 Members · 7 Replies -
Peter Mcauley
June 21, 2006 at 5:19 pmHi Rick,
The short answer is no, the only product that we develop which currently runs in FCP 5.1.1 is Boris Calligraphy, which is included as a part of the FCP product installation. We are cognizant of the fact that we need to support this version of FCP with our product line and we are working toward that goal but I cannot commit to a set completion date just yet. Please stay in touch with us and I will provide you with a report on our progress in that regard as we come close to a solution. Also, please feel free to contact me directly at peterm@borisfx.com should you need to discuss this further.
Cheers,
Peter.
Peter Mcauley
June 21, 2006 at 6:23 pmHi Rick,
I have a correction to my last post … the current versions of our products actually will run inside of FCP 5.1.1 as long as you are running FCP on a non-Intel Mac (I had incorrectly assumed that you were on a Mac Intel machine when I wrote the last post.) Our tech support team are in he process of getting in touch with you directly to sort this issue out.
Cheers,
Peter.
Tim Langston
June 22, 2006 at 5:12 pmSince we’re talking about Red 3.0.5….I can use it as a generator, once I try to use it as a filter or try the transitions….with caps lock on it doesn’t work. If I go in and delete prefs it seems to work for a day or so.
So I guess just keep deleting prefs and I’ll be fine???
Tim
Tim Langston
Cryin’ Out Loud Productions
Fort Wayne, IN
http://www.colproductions.com -
Peter Mcauley
June 22, 2006 at 6:06 pmHi Tim,
That sounds kind of ugly … let’s see what our tech support guru’s have to say.
Peter.
Rs3 Prod
June 23, 2006 at 5:30 pmWell after taling to the Tech reps at Boris. RED 3.0.5.0 does work with 5.1.1. The only problem is that you have to do alot more then what the hand out tells you. You hav eto uninstall red and reinstall it and throw away all the prefs of red in your system. Then it all works like a charm.
Rick Simpson
RS3Productions
Pensacola, Fl
http://www.web.mac.com/saleen281 -
Tim Langston
June 24, 2006 at 4:40 pmWhere do you find all the files to delete? Did they give you a list?
TimTim Langston
Fort Wayne, IN
Paul Fx
June 27, 2006 at 4:31 pmTim, send your email address to support@borisfx.com and I can send you the steps to fix your problem.
Paul
