Activity Forums Boris FX Boris Red 3 GL in Premiere Pro Text Probs
  • Boris Red 3 GL in Premiere Pro Text Probs
    Posted by Don Solomon on August 18, 2005 at 3:30 am
    I am having trouble getting the Red 3 text effect presets to work completely in Premiere Pro 1.5. If I attempt to modify the text of a preset by changing color, material, or any other attribute, it will not Update. The original preset will work fine, but all modifications of the existing, or new, text remain black in the Text editing window and on the Premiere preview window. Also, Red manipulations garbage my premiere screen, allowing large blocks of the window beneath to show through. That is easily corrected by minimizing Prem Pro and then restoring it. What am I doing wrong, or are these known problems with Red in Prem Pro 1.5? Is anyone using Red 3 in Prem Pro 1.5 without glitches? I certainly don’t want to buy it if I can’t get the text effects going, since that is my interest in getting it. TIA
    don
    Pedigree-punk replied 20 years, 11 months ago 2 Members · 1 Reply
  • Pedigree-punk
    September 28, 2005 at 8:00 pm
    For what it’s worth..I too have had trouble with Premiere failing to update changes to Boris Comps applied to clips, amongst other things..see post above.. also experienced the screen garbage you mention which is not very confidence inspiring.
