Activity Forums Boris FX Boris Products – Text generators
  • Boris Products – Text generators
    Posted by Brandon Hite on August 22, 2009 at 4:11 pm
    I am trying to create a countdown timer. I have tried both Graffiti and Blue and I get the same results.
    Using the timecode option in the text generator, I can adjust almost every parameter although in the transform tab, it allows you to select a different font and size, but it never takes the change and always defaults back to ‘Arial Narrow.’
    Is this just a bug or am I doing something dumb?
    Any suggestions…????
    Brandon Hite
    Peter Mcauley replied 17 years ago 2 Members · 1 Reply
  • Peter Mcauley
    August 24, 2009 at 11:03 pm
    Hi Brandon,
    Sounds rather odd alright and not the expected behavior. With a text track selected in the timeline, if you click on the face sub-track and make adjustments to parameters in the Controls Window the changes should stick. I’m not sure why they are not. Try double-clicking the top level text track – this action opens the text generator window. Then make sure that the text is selected in the text generator window and change the font – does this change stick?
    Hope this helps,
    Peter.
