Activity Forums Boris FX Boris Optical Flow.
  • Boris Optical Flow.
    Posted by Shaunie Woods on March 31, 2012 at 12:38 pm
    Hello All,
    First off, forgive my lack of sustainable editing language, i’ll try to be as forthright and semantic as I can.
    I am editing a short film I made and part of the film I have people’s reactions to noises in the house, it is one big file and I took it continuously.
    I am now trying to edit it a bit like “Evil Dead”, in the sense that I am speeding up the footage and skiping frames, hence giving it a little strange look.
    I am using Boris Optical Flow, however, I am getting rather peculiar results. I chop import the footage into after effects and I apply Optical Flow, however, the footage actually changes and effectively applies itself to another part of the footage.
    This is irritating to say the least and I was wondering if anyone had any other solutions?
    Peter Mcauley replied 14 years, 5 months ago 2 Members · 1 Reply
  • Peter Mcauley
    April 2, 2012 at 2:20 am
    Hi Shaunie,
    I suspect the problem is with applying the optical flow filter to a trimmed clip. Precomp the clip in After Effects before you apply the optical flow filter and you should get the results that you were expecting.
    I hope this helps.
    Peter.
