Activity › Forums › Boris FX › Boris Match Move in Final Cut Pro X
  • Boris Match Move in Final Cut Pro X
    Posted by Rich Milo on May 28, 2013 at 10:02 pm
    Hi
    I have a case to use this filter, but I really can’t figure it out.
    Can anyone point me to a tutorial on how to use Boris Match Move on Final Cut Pro X?
    I have googled, in fact I have spent the past two hours doing just that. All I can find are tutorials using Vegas, or old versions of Final Cut and I can’t get any sense out of them.
    Any pointers would be really appreciated.
    Thank you!
    Rich
    Jaeson Koszarsky replied 13 years, 3 months ago 3 Members · 5 Replies
  • Dirk De jong
    May 29, 2013 at 5:27 pm
    here’s something (best viewed @ 720p on youtube site) ;
    https://www.youtube.com/watch?v=l2qKA9eVKtI
  • Rich Milo
    May 30, 2013 at 7:01 pm
    Thank you so much! That has really been a great help to me.
    I wonder why I couldn’t find this video when I searched in YouTube though…
    Thanks again – that explains everything I need
  • Rich Milo
    May 30, 2013 at 8:24 pm
    Hi again
    I wonder if you could offer some more advice. Basically the tracker is running like an absolute slug – I mean around half an hour to process 10%!
    Are there any tips for increasing performance? I could be horribly under specced – I’m using an iMac i5 2.5gz with 8gb of ram. The clip is only 50 seconds long, at 720p and 59 fps. I tried to drop the framerate but if anything it seemed to make it slower.
    On your video it was pretty much instantaneous – but you may have 32 cores, ssd, and 128gb of ram 🙂
    Thanks for any pointers
    Rich
  • Dirk De jong
    May 30, 2013 at 9:25 pm
    In the “Playback” tab of the Final Cut Pro Preferences, using proxy media (once you’ve generated proxy media – File menu / choose “Transcode Media”) and/or setting the Playback Quality to “Better Performance” while tracking can help. The “Better Performance” setting is only relevant for realtime playback but the proxy media applies to all operations while the proxy setting is chosen. That screencapture movie was recorded on an iMac i7 2.93GHz with 8gigs RAM but I think it was tracking proxy media.
  • Jaeson Koszarsky
    June 10, 2013 at 7:51 pm
    If you turn on motion-blur, you’ll watch the system come to a crawl if it’s set to a high quality level.
    Jaeson
