Activity Forums Boris FX Boris is SLOOOOOW & unstable
  • Boris is SLOOOOOW & unstable
    Posted by Richard Kenmuir on September 10, 2010 at 8:19 pm
    Guys,
    i have been working with Pinnacle ultimate and Boris FX for the past week trying to render a 1 hr project.
    1. i will start the render to DVD process and Boris is so slow i am literally rendering a frame every second.
    2. at a point about 30% through the project i get a message that there is “not enough memory” and the rendering process just stops.
    3. when i try to move into the rendering process i keep getting the same message.
    I am using a decent computer and just added 2 Gig or RAM. After adding this Boris promptly consumed all of that extra memory!
    Either i am missing something or this program is a memory HOG.
    Peter Mcauley replied 16 years ago 2 Members · 1 Reply
  • Peter Mcauley
    September 13, 2010 at 3:08 pm
    Hi Richard,
    The render performance of BFX is totally dependent on the frame size and complexity of the effect that you are attempting to generate. Please feel free to send me the BFX project file and I can test that within a different host environment to see if it’s related to (a) working within that particular host environment or (b) the hardware of the system that you are using or (c) the setting itself. Also, have you tried to render to DVD with the Boris effects disabled to understand how much the effects are adding to the render time? Please feel free to send the project file to me at peterm@borisfx.com.
    Cheers,
    Peter.
