Activity Forums Apple Final Cut Pro Legacy Boris in FCP 5
  • Posted by Stollie on November 28, 2006 at 10:28 pm
    I’m a relatively new FCP user and used to use Media 100 with Boris Graffiti and FX. I’d like to use Boris as stand alone and import back into FCP. Is there a way to do this? Please help a newbie!
    Stollie replied 19 years, 5 months ago 3 Members · 3 Replies
  • Walter Biscardi
    November 29, 2006 at 12:39 am
    [stollie] “I’d like to use Boris as stand alone and import back into FCP.”
    Boris 3D is essentially Grafitti built into FCP. You can also purchase the appropriate Boris FX version for FCP.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
  • Doug Olin
    November 29, 2006 at 4:53 pm
    Boris Red can be used as a stand alone or as a plugin for FCP. I’m not sure that Boris FX can be used as a stand alone. Boris Red is like FX and Graffiti combined so it might be worth considering. I use Red regularly with FCP and wouldn’t want to edit without it.
    Doug Olin
    Desert Vistas Multimedia
    http://www.desertvistasmm.com
  • Stollie
    November 30, 2006 at 2:11 pm
    Thanks for the comments.
    I see the plug-in, but unless I’m not seeing it, the Boris plug-in doesn’t give you all the features you have with the full program. Hmmmm…
