Activity Forums Boris FX Boris IMPORTING STILLS problem
  • Boris IMPORTING STILLS problem
    Posted by Steve Mott on November 18, 2015 at 10:29 pm
    When I import a photo file(square pixels) using either BorisFX red engine or AvidFX, Boris imports the image smaller than it’s native size. In the Media Info window: Image size – Boris displays the native size and also the imported size. I created new compositions and imported different images – didn’t work. I closed out and restarted the program – didn’t work. Restarted computer – didn’t work. Finally, shut down and restarted…this also didn’t work either. Anybody have any idea why?
    Steve Mott replied 10 years, 7 months ago 2 Members · 2 Replies
  • Jon Kozenko
    November 19, 2015 at 5:53 pm
    Hello Steve,
    When you Import, are you doing this by using the File > Import command, or are you using the ‘Add Image Media’ button in the RED timeline? If you’re going through the File > Import approach, does using the Add Image Media approach cause the same problem? Is this happening in the stand-alone version of the RED or Avid FX engines, or just when loaded from Avid (or any other host)? Lastly, is it both the X and Y pixels that are adjusting, or just one of these two dimensions?
    Jon
  • Steve Mott
    November 30, 2015 at 3:50 pm
    Ended up being the preview quality and preview resolution I was working in. While working in lo-res, the import size reflects this change.
