Activity Forums Apple Final Cut Pro Legacy Boris… I know it SHOULD work…
  • Boris… I know it SHOULD work…
    Posted by Nick Ryan on December 22, 2005 at 10:36 pm
    Boris Red, an amazing program right? I’d like to take advantage of it, keep up with the other editors in my department, and immerse myself in award-winning Boris-assisted success – but I can’t. My link from FCP to Boris Red doesn’t work and never has. I’m running FCP 5.0.4 (just updated today from 5.0.3 – same problem) with Boris 3.0 (tried downloading and installing the 3.0.4 update – didn’t help). The Red standalone engine works fine, but applying a Red transition in FCP is a no go. I can lay the transition down on the timeline (at the juncture of two adjoining clips of course), and double-click it to load it into the viewer, but when I click on the grey “options” button or the red logoed button to open Red nothing happens. The transition on the timeline remains an unrendered nothingness.
    We tried (as I said) downloading and installing the Red 3.0.4 update with no good fortune, and we also tried reinstalling Red completely (along with the update again). Alas, no progress. Does Red even work with FCP 5? The editor in the next room uses Red successfully all day long – but he’s cutting on FCP 4.5.
    Any thoughts?
    Nick
    Nick Ryan replied 20 years, 9 months ago 4 Members · 9 Replies
  • 9 Replies
  • David Bogie
    December 22, 2005 at 11:14 pm
    Contact Boris, best bet. All I can tell you is that it does indeed work. Has on my machine since Red’s prototype days with Media 100 and all versions of FCP and Macintosh OS9-10.
    Does Boris Red’s interconnect work on any of your other systems?
    bogiesan
  • Chris Babbitt
    December 23, 2005 at 5:36 am
    I had a similar issue with BorisFX and FCP. Sorry, but I can’t remember exactly what I did to remedy the problem, but I did. I would suggest doing a search in Spotlight for eveything Boris, and then deleting all the files; then re-installing.
  • Derek Woods
    December 23, 2005 at 1:39 pm
    Have to ask- is the scrubber ON the transition when you click on it? Boris will NOT open if its not. This actually took me a while to figure out at first,( so don’t say its a silly question):)
  • David Bogie
    December 23, 2005 at 4:44 pm
    Hmm, good point, derek.
    We patiently await response from the original poster.
    bogiesan
  • Nick Ryan
    December 24, 2005 at 9:20 am
    Ah, a good point indeed – and I take no offense. The answer is yes, the scrubber is on the transition point while the link still fails to work.
    Good thought though.
  • Derek Woods
    December 24, 2005 at 1:24 pm
    Well, i have boris 304 on fcp504 and it works fine. Does any Boris Red generators work in fcp for you?
  • Nick Ryan
    December 24, 2005 at 9:25 pm
    Yes… I was unaware until you asked… If I throw a Boris filter on there it will link over, but the Boris transition will not. Actually (I hate to say it) I just got the Boris transition link to work once – putting the 2nd clip on the track above, but I tried it again further down the pike with different clips and no go. The randomness makes me think there might be a corrupt file somewhere? Prefs have been trashed many a time…
    Nick
  • Derek Woods
    December 25, 2005 at 1:48 pm
    I think its time to call Boris tech-they are usually really good!
  • Nick Ryan
    December 26, 2005 at 10:11 pm
    Will do…
    Nick
